Salta al contenuto principale
Timex W-10 Children's Watch Battery Replacement
Cosa ti serve
  1. Timex W-10 Children's Watch Battery Replacement, Battery: passo 1, immagine 1 di 3 Timex W-10 Children's Watch Battery Replacement, Battery: passo 1, immagine 2 di 3 Timex W-10 Children's Watch Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: passo 2, immagine 1 di 2 Timex W-10 Children's Watch Battery Replacement: passo 2, immagine 2 di 2
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: passo 3, immagine 1 di 2 Timex W-10 Children's Watch Battery Replacement: passo 3, immagine 2 di 2
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: passo 4, immagine 1 di 2 Timex W-10 Children's Watch Battery Replacement: passo 4, immagine 2 di 2
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: passo 5, immagine 1 di 2 Timex W-10 Children's Watch Battery Replacement: passo 5, immagine 2 di 2
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
Conclusione
2 Commenti
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - Replica
Daniel Melendrez - June 12
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 46
Tutti i Tempi: 8,189
