1. Does your front male clip look like this? Follow these easy steps to get your messenger bag back up to fighting shape! Here are the things you'll need:
    • Does your front male clip look like this? Follow these easy steps to get your messenger bag back up to fighting shape!
    • Here are the things you'll need:
      • You'll need a new male clip. Get it here!
      • Wire cutters or heavy duty scissors.
  2. Using wire cutters or heavy duty scissors, break off old male clip and remove from fabric. Insert scissors in the space between the strap and the buckle's first loop and cut through. Next, insert scissors in second loop between the strap and the buckle's second loop and cut through. (It is easier to cut on the inside edges of the loops than to cut the loops in the center) Insert scissors in the space between the strap and the buckle's first loop and cut through. Next, insert scissors in second loop between the strap and the buckle's second loop and cut through. (It is easier to cut on the inside edges of the loops than to cut the loops in the center)
    • Using wire cutters or heavy duty scissors, break off old male clip and remove from fabric.
      • Insert scissors in the space between the strap and the buckle's first loop and cut through. Next, insert scissors in second loop between the strap and the buckle's second loop and cut through. (It is easier to cut on the inside edges of the loops than to cut the loops in the center)
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. This is where your new male clip will come in handy.
    • This is where your new male clip will come in handy.
  5. Insert new 1 inch male buckle in existing female buckle. Take strap and insert it from the back side of the buckle, through the top loop. Next, insert the rest of the strap through the bottom loop and pull though.
    • Insert new 1 inch male buckle in existing female buckle.
    • Take strap and insert it from the back side of the buckle, through the top loop.
    • Next, insert the rest of the strap through the bottom loop and pull though.
  6. You're all done!
    • You're all done!
Linea Traguardo
Altre 5 persone hanno completato questa guida.
Emilee
Membro da: 13/03/2014
1.341 Reputazione
9 Guide realizzate
Thanks for this guide! I tried pulling the strap through the old clip and it wouldn't go through, so I thought I had to cut and re-sew the ends. I am so glad I saw this, saved me a lot of work! Thanks again!
Phone Person - Replica
Thank you so much for this! My pup chewed the clip off of my bag less than two weeks after purchase. I was bummed. Went to the Timbuk2 site and all these reviews said I had to cut and resew the ends…. I KNEW there had to be a better way. Took me less than 5 minutes. Thank you, Thank you, Thank you!!!
wmc - Replica
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 128
Tutti i Tempi: 7,369
