Salta al contenuto principale
Tiger Rice cooker Internal Battery Replacement
Cosa ti serve
  1. Tiger Rice cooker Internal Battery Replacement, Disassemble Base: passo 1, immagine 1 di 1
    • Unplug the rice cooker!
    • Place a soft item on the bench, to prevent scratching the lid
    • Remove the four screws from the base. Take note - each screw has a black washer, but the rear two screws also include a white spacer.
  2. Tiger Rice cooker Internal Battery Replacement, Record details of connectors: passo 2, immagine 1 di 2 Tiger Rice cooker Internal Battery Replacement, Record details of connectors: passo 2, immagine 2 di 2
    • Lift the lid off carefully (rotate it from the front to the back). It is attached electrical via cords - treat it very carefully.
    • Take note of the connections onto the main board of the rice cooker. Suggest you photograph these connections before you remove any of them!
  3. Tiger Rice cooker Internal Battery Replacement, Remove electronic board assembly: passo 3, immagine 1 di 2 Tiger Rice cooker Internal Battery Replacement, Remove electronic board assembly: passo 3, immagine 2 di 2
    • Remove the two phillips head screws holding the main electronic board in place. The arrows indicate location of the two screws (but they are at the back of the board)
    • Once the board is removed, disconnect all the electronic cords connecting the board to the rice cooker. As mentioned before, ensure you take a photo of the location of the connectors before removing!
    • With the board removed, the LCD panel is exposed. Take care of this and the cavity (as any dirt falling in will cover the LCD panel when re-installed)
  4. Tiger Rice cooker Internal Battery Replacement, Battery details: passo 4, immagine 1 di 3 Tiger Rice cooker Internal Battery Replacement, Battery details: passo 4, immagine 2 di 3 Tiger Rice cooker Internal Battery Replacement, Battery details: passo 4, immagine 3 di 3
    • With the screws removed, the main board assembly can be lifted out. It is connected to the LCD panel and buttons by flexible cable, so be careful working on the board.
    • The battery to be replaced is shown in the picture. As indicated, it is soldered onto the board.
    • The battery removed from the board is shown for reference.
  5. Tiger Rice cooker Internal Battery Replacement, Remove board from assembly: passo 5, immagine 1 di 1
    • The board must be removed from the assembly.
    • Screws are indicated in the picture.
  6. Tiger Rice cooker Internal Battery Replacement, Remove battery & replace: passo 6, immagine 1 di 3 Tiger Rice cooker Internal Battery Replacement, Remove battery & replace: passo 6, immagine 2 di 3 Tiger Rice cooker Internal Battery Replacement, Remove battery & replace: passo 6, immagine 3 di 3
    • The battery must be removed by desoldering the two positions shown. Take note of the polarity of the battery before removal.
    • Desolder the points and remove the battery.
    • Solder the new battery in place, maintaining polarity.
    • New battery installed here - the new battery had a plastic ring around it. The tabs may be in slightly different positions and may require manipulation to fit into the existing location
    • Once the battery has been connected, check the display panel to see if the clock is flashing - this will indicate the battery is connected.
Conclusione
Altre 8 persone hanno completato questa guida.
Nils
Membro da: 03/07/17
372 Reputazione
1 Guida realizzata
13 Commenti
Pro tip, order a CR2450 battery holder with 20mm pin spacing and solder that in instead. Costs $1. Then use a normal CR2450 button battery, they are cheaper and can be replaced easily next time.
My model was slightly different JBA-T10A.
After removing the 4 base screws I had to lever the base off with a flat screw driver.
No need to disconnect the power wires, the power socket slides out from the plastic base.
3 screws hold the circuit board.
Colin Berg - Replica
Hi Colin, are you able to post a link to a website that you got the battery holder from?
Kenny Low -
I got a holder and Panasonic battery on eBay.
dazwelnz -
Also you could use a cr2477 as it has same diameter but larger capacity.
dazwelnz -
Thanks for the suggestion about the battery holder. I’ve just replaced the original battery in our ~6 year of rice cooker. I was able to just reflow the existing solder so it was an easy swap. One resistor ended up slightly under the battery holder so the holder is slightly canted, but that won’t be a problem.
Richard Brockie -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 145
Tutti i Tempi: 25,587
