Parti
Nessuna parte richiesta.
  1. Power down the TiVo and detach the power cable from the rear of the unit.
    • Power down the TiVo and detach the power cable from the rear of the unit.
      • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. Remove the five T10 screws from the rear of the case using the Torx screwdriver.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Lift up and pull back the outer casing towards the rear of the unit. Lift up and pull back the outer casing towards the rear of the unit.
    • Lift up and pull back the outer casing towards the rear of the unit.
  5. The fan is held in by four T15 screws on the rear of the device.
    • The fan is held in by four T15 screws on the rear of the device.
  6. Take the wound red and black wires coming from the fan and follow them back to the logic board. Unplug the connector from the motherboard.
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  7. Pull the fan towards the front and out of the TiVo unit. Pull the fan towards the front and out of the TiVo unit.
    • Pull the fan towards the front and out of the TiVo unit.
Conclusione
Cal Poly, Team 33-79, Johann Spring 2010 Membro di Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,071
