Introduzione
In case your remote just won't work and you have already tried replacing the batteries, this guide will walk you through removing the front cover and replacing the remote sensor on the inside of the cover.
Parti
Nessuna parte richiesta.
Unscrew the five 0.31 inch T-9 screws on the back cover.
  • Unscrew the five 0.31 inch T-9 screws on the back cover.
Aggiungi Commento
Slide the cover towards the back until it is no longer under the front cover.
  • Slide the cover towards the back until it is no longer under the front cover.
Aggiungi Commento
  • Lift the cover up and off the device.
Aggiungi Commento
  • Unplug the ribbon cable from the motherboard. Some force may be required for this step, so be careful not to rip the ribbon cable.
Aggiungi Commento
  • Unscrew the two 0.31 inch T-9 screws on the inside of the front cover.
Aggiungi Commento
  • Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover.
Aggiungi Commento
  • Pull the front cover down and away from the device to separate it completely. Be careful not to tear the ribbon cable as you are removing the front cover.
Aggiungi Commento
  • Unscrew the two 0.31 inch T-9 screws on the back of the sensor.
Aggiungi Commento
  • Lift the sensor up to remove it.
Aggiungi Commento
Conclusione
Shauna
Membro da: 10/10/2011
37 Reputazione
2 Guide realizzate
Cal Poly, Team 5-33, Amido Fall 2011 Membro di Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 899
