Salta al contenuto principale
TiVo Series 2 TCD24008A Motherboard Replacement
Cosa ti serve
  1. TiVo Series 2 TCD24008A Motherboard Replacement, Cover: passo 1, immagine 1 di 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the two 0.59 inch T-8 size screws on the back panel
  5. TiVo Series 2 TCD24008A Motherboard Replacement: passo 5, immagine 1 di 1
    • Unplug the fan from the motherboard by gently pulling up on the red plug.
  6. TiVo Series 2 TCD24008A Motherboard Replacement: passo 6, immagine 1 di 1
    • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  7. TiVo Series 2 TCD24008A Motherboard Replacement: passo 7, immagine 1 di 1
    • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  8. TiVo Series 2 TCD24008A Motherboard Replacement: passo 8, immagine 1 di 1
    • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  9. TiVo Series 2 TCD24008A Motherboard Replacement: passo 9, immagine 1 di 2 TiVo Series 2 TCD24008A Motherboard Replacement: passo 9, immagine 2 di 2
    • Locate the four metal tabs on the motherboard.
    • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
  10. TiVo Series 2 TCD24008A Motherboard Replacement: passo 10, immagine 1 di 1
    • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  11. TiVo Series 2 TCD24008A Motherboard Replacement: passo 11, immagine 1 di 2 TiVo Series 2 TCD24008A Motherboard Replacement: passo 11, immagine 2 di 2
    • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
    • Pull up and away from the back panel so all of the cable inputs slip through the casing.
Conclusione
Cody Hunter
Membro da: 10/10/11
22 Reputazione
2 Guide realizzate
Cal Poly, Team 5-33, Amido Fall 2011 Membro di Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,105
