Salta al contenuto principale
TiVo Premiere XL4 Fan Replacement
Cosa ti serve
  1. TiVo Premiere XL4 Fan Replacement, Case: passo 1, immagine 1 di 1
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. TiVo Premiere XL4 Fan Replacement: passo 2, immagine 1 di 2 TiVo Premiere XL4 Fan Replacement: passo 2, immagine 2 di 2
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. TiVo Premiere XL4 Fan Replacement: passo 3, immagine 1 di 1
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
  4. TiVo Premiere XL4 Fan Replacement, Fan: passo 4, immagine 1 di 1
    • Use the Torx screwdriver to remove the four 100mm T15 screws.
  5. TiVo Premiere XL4 Fan Replacement: passo 5, immagine 1 di 1
    • Follow the combined black and red cables to the connector that is connected to the motherboard.
    • Pinch the connector and gently remove from the motherboard.
  6. TiVo Premiere XL4 Fan Replacement: passo 6, immagine 1 di 2 TiVo Premiere XL4 Fan Replacement: passo 6, immagine 2 di 2
    • Remove the fan from the TiVo unit.
Conclusione
Baylor, Team S1-G1, Williams Fall 2018 Membro di Baylor, Team S1-G1, Williams Fall 2018
BU-WILLIAMS-F18S1G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 504
