Salta al contenuto principale
Thrustmaster T Flight Hotas 4 Trigger Replacement
Cosa ti serve
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: passo 1, immagine 1 di 2 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: passo 1, immagine 2 di 2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: passo 2, immagine 1 di 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: passo 2, immagine 2 di 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: passo 2, immagine 3 di 3
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 3, immagine 1 di 1
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 4, immagine 1 di 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 4, immagine 2 di 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: passo 4, immagine 3 di 3
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
Conclusione
Aaron Banaga
Membro da: 09/11/17
526 Reputazione
4 Guide realizzate
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,390
