Salta al contenuto principale
Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement
Cosa ti serve
  1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, J1 Screws on Throttle: passo 1, immagine 1 di 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: passo 2, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: passo 2, immagine 2 di 2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: passo 3, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: passo 3, immagine 2 di 2
    • Remove the two 8 mm J1 JIS head screws.
  4. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 4, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 4, immagine 2 di 2
    • Remove exterior panel from the throttle by using your hands to gently pull the panel away.
  5. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 5, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 5, immagine 2 di 2
    • Remove the two 6 mm J1 JIS head screws from the circuit board.
  6. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 6, immagine 1 di 1
    • Carefully remove the circuit board.
  7. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 7, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 7, immagine 2 di 2
    • Remove the 6 mm J1 JIS head screw that is attached to the black plastic cover.
  8. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 8, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 8, immagine 2 di 2
    • Remove black plastic cover.
  9. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 9, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 9, immagine 2 di 2
    • Once the black plastic cover is removed, push the buttons inward from the outside of the device.
    • Be aware of the springs. They are small and easy to lose.
    • This step only replaces the x, square, and circle buttons.
  10. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 10, immagine 1 di 2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 10, immagine 2 di 2
    • Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
    • Removal of the screws will detach the exterior panel from the device.
  11. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 11, immagine 1 di 1
    • Carefully remove tan plastic cover.
  12. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: passo 12, immagine 1 di 1
    • Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
Conclusione
Aaron Banaga
Membro da: 09/11/17
526 Reputazione
4 Guide realizzate
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Membri
13 Guide realizzate
Un commento
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
Anthony Vallillo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,572
