Salta al contenuto principale
Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement
Cosa ti serve
  1. Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: passo 1, immagine 1 di 2 Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: passo 1, immagine 2 di 2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
Conclusione
Altre 3 persone hanno completato questa guida.
Aaron Banaga
Membro da: 09/11/17
526 Reputazione
4 Guide realizzate
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Membri
13 Guide realizzate
4 Commenti
there are small plastic pieces in mine, when i took it off now my joystick wont work or turn properly and I havent found any guide to where these pieces go??
beardy1 - Replica
I'm wondering the same thing right now. That round spring with the arms on it and the black lC shaped plastic piece.
Brent Taylor-Wooster -
On the bottom of the stick assembly you will see a small slot head screw like indent. That is a built in manual stop, rotate 45 to 90 degrees in the loosening direction, it will un lock
Edit: I was trying to include 3 pictures of the assembly and install but no luck sorry
Timothy Brake -
I found this link which shows where that black plastic piece goes: https://channellfd.com/t-flight-hotas-x-...
You know how there are three holes on the bottom of the stick, but only two screws? It goes in the third hole.
HolleringHuskarl -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,868
