Salta al contenuto principale
Thrustmaster T Flight Hotas 4 J1 Screws on Bottom Panel Replacement
Cosa ti serve
  1. Thrustmaster T Flight Hotas 4 J1 Screws on Bottom Panel Replacement, J1 Screws on Bottom Panel: passo 1, immagine 1 di 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Turn the controller upside down.
    • Remove the 20 mm J1 JIS head screw.
    • Remove the six 12 mm J1 JIS head screws.
    • Remove the two 6 mm J1 JIS head screws.
  2. Thrustmaster T Flight Hotas 4 J1 Screws on Bottom Panel Replacement: passo 2, immagine 1 di 1
    • Insert opening tool or finger into the divet located beneath the USB port.
Conclusione
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,583
