Salta al contenuto principale
Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement
  1. Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Disassemble: passo 1, immagine 1 di 2 Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Disassemble: passo 1, immagine 2 di 2
    • Remove the frame with a soft thin plastic tool (or finger-nails)
    • Carefully remove the keyboard from the back-cover. There is quite a lot of double sided tape. Be careful to not bend the metal frame of the keyboard.
    • As a result, you will be able to separate the keyboard from tha back cover. Only two flex PCB cables are still connecting them.
  2. Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Disconnect the flex PCB connections: passo 2, immagine 1 di 3 Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Disconnect the flex PCB connections: passo 2, immagine 2 di 3 Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Disconnect the flex PCB connections: passo 2, immagine 3 di 3
    • Both flex PCB connections need to be disconnected. This is done by lifting the lids on CN2 and CN3.
    • Careful to not lose the lid of connector CN2. It might come lose.
    • The PCB needs to be removed from the back shell. It is also glued in with double sided tape. Fortunately the back of the PCB is not having any components.
    • The USB-C connector component chosen was the USB4520-03-1-A made by GCT
    • You can buy it e.g. at Digi-Key
    • Datasheet https://gct.co/files/drawings/usb4520.pd...
    • Digi-Key: https://www.digikey.com/en/products/deta...
    • After unsoldering the Micro-B connector the sides of the rectangular cutout needs to be filed out very little to make space for the slightly wider new connector
    • File out also the opening in the back shell to allow the new part to fit through.
  3. Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Soldering in the new connector: passo 4, immagine 1 di 2 Thinkpad USB Keyboard: Upgrade to USB-C Connector Replacement, Soldering in the new connector: passo 4, immagine 2 di 2
    • In the image the soldering and how it maps to the pads on the PCB are shown.
    • The GND can be connected to the large copper area. Just scratch away a bit of the green isolating layer. A bit of flux helps.
    • The soldering of the data lines is abit fiddly and rather for people with some soldering skills. Thin coil wire is a helpful.
    • In yellow the CC2 connection is shown. It requires a 5.1kOhm resistor to GND for correct identification by USB standard. The yellow rectangle represents the small SMD resistor.
    • If rotation of the cable is not needed, the data lines can be soldered to only the two 1DP and 1DN pins.
    • After testing, reassemble the whole keyboard. Thelast image shows how the USB-C fits into the opening.
Conclusione
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Nomis
Membro da: 04/24/18
259 Reputazione
2 Guide realizzate
1Commento della guida
It's worth noting that, as long as it's not too badly damaged, the original micro-b connector can be repaired and solidified by pushing down on it and putting a drop of solder on top of it. I followed this guide and found that I didn't need to go as far as replacing the connector to make the keyboard usable again.
MatthewGB - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 97
Tutti i Tempi: 1,848
