Salta al contenuto principale
ThinkPad Yoga 12 SSD Replacement
Cosa ti serve
  1. ThinkPad Yoga 12 SSD Replacement, Screws: passo 1, immagine 1 di 3 ThinkPad Yoga 12 SSD Replacement, Screws: passo 1, immagine 2 di 3 ThinkPad Yoga 12 SSD Replacement, Screws: passo 1, immagine 3 di 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 SSD Replacement, Prying: passo 2, immagine 1 di 2 ThinkPad Yoga 12 SSD Replacement, Prying: passo 2, immagine 2 di 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: passo 3, immagine 1 di 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: passo 4, immagine 1 di 2 ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: passo 4, immagine 2 di 2
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  5. ThinkPad Yoga 12 SSD Replacement: passo 5, immagine 1 di 2 ThinkPad Yoga 12 SSD Replacement: passo 5, immagine 2 di 2
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  6. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: passo 6, immagine 1 di 2 ThinkPad Yoga 12 SSD Replacement, Remove enclosure: passo 6, immagine 2 di 2
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  7. ThinkPad Yoga 12 SSD Replacement, Done!: passo 7, immagine 1 di 2 ThinkPad Yoga 12 SSD Replacement, Done!: passo 7, immagine 2 di 2
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
Conclusione
Altre 6 persone hanno completato questa guida.
[deleted]
Membro da: 03/18/18
1.324 Reputazione
3 Guide realizzate
Un commento
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,868
