Salta al contenuto principale
ThinkPad Yoga 12 Battery Replacement
Cosa ti serve
  1. ThinkPad Yoga 12 Battery Replacement, Screws: passo 1, immagine 1 di 3 ThinkPad Yoga 12 Battery Replacement, Screws: passo 1, immagine 2 di 3 ThinkPad Yoga 12 Battery Replacement, Screws: passo 1, immagine 3 di 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Battery Replacement, Prying: passo 2, immagine 1 di 2 ThinkPad Yoga 12 Battery Replacement, Prying: passo 2, immagine 2 di 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: passo 3, immagine 1 di 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: passo 4, immagine 1 di 2 ThinkPad Yoga 12 Battery Replacement, Removing the screw: passo 4, immagine 2 di 2
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: passo 5, immagine 1 di 2 ThinkPad Yoga 12 Battery Replacement, Lift: passo 5, immagine 2 di 2
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: passo 6, immagine 1 di 3 ThinkPad Yoga 12 Battery Replacement, Connecter: passo 6, immagine 2 di 3 ThinkPad Yoga 12 Battery Replacement, Connecter: passo 6, immagine 3 di 3
    • Carefully pull the connector out from underneath the logic board to remove the battery.
Conclusione
Altre 9 persone hanno completato questa guida.
[deleted]
Membro da: 03/18/18
1.324 Reputazione
3 Guide realizzate
Un commento
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 6,516
