Salta al contenuto principale
ThinkPad X1 Carbon Wireless Card Replacement
Cosa ti serve
  1. ThinkPad X1 Carbon Wireless Card Replacement, Loosen Cover Screws: passo 1, immagine 1 di 1
    • Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
  2. ThinkPad X1 Carbon Wireless Card Replacement: passo 2, immagine 1 di 1
    • Using the spudger pop the cover loose and remove.
  3. ThinkPad X1 Carbon Wireless Card Replacement, Disconnect Battery: passo 3, immagine 1 di 1
    • Use only plastic tools to disconnect battery cable
    • Slide battery connector in the direction if the arrow to disconnect.
    • You can leave the battery or remove it using the red circles for the screw locations.
  4. ThinkPad X1 Carbon Wireless Card Replacement: passo 4, immagine 1 di 1
    • Remove screw holding the wireless card in place.
  5. ThinkPad X1 Carbon Wireless Card Replacement, Remove Antenna Cables: passo 5, immagine 1 di 1
    • Carefully remove the antenna cables and slide out the card in the direction of the arrow.
    • The gray connector is on the top. The black connector is closer to the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Mike
Membro da: 06/23/16
1.834 Reputazione
5 Guide realizzate
iReconstruction Membro di iReconstruction
Business
1 Membro
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 43
Tutti i Tempi: 5,402
