Salta al contenuto principale
ThinkPad X1 Carbon Fingerprint Reader Replacement
Cosa ti serve
  1. ThinkPad X1 Carbon Fingerprint Reader Replacement, Fingerprint Reader: passo 1, immagine 1 di 1
    • Unscrew the seven screws located on the back of the device.
  2. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 2, immagine 1 di 1
    • Slide the plastic opening tool along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 3, immagine 1 di 1
    • Flip the device over and open it to lift the keyboard tray from the body of the device.
  4. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to gently release the ribbon cable attached to the keyboard.
    • You may now place the device off to the side. The rest of the repair takes place on the keyboard tray.
  5. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 5, immagine 1 di 1
    • Locate the Fingerprint Reader and metal frame on the left side of the keyboard tray.
  6. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 6, immagine 1 di 1
    • Unscrew the two silver screws to remove the metal frame.
  7. ThinkPad X1 Carbon Fingerprint Reader Replacement: passo 7, immagine 1 di 1
    • Remove the ribbon cable connected to the board.
    • Remove and Replace the Fingerprint Reader board and metal frame.
    • This connection does not have a lock, please pull the ribbon away from the board. Do not attempt to lift the connection.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,766
