Salta al contenuto principale
ThinkPad X1 Carbon Battery Replacement
Cosa ti serve
  1. ThinkPad X1 Carbon Battery Replacement, Loosen Cover Screws: passo 1, immagine 1 di 1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Battery Replacement, Remove Cover: passo 2, immagine 1 di 1
    • Use spudger to pop loose cover and slide off.
  3. ThinkPad X1 Carbon Battery Replacement, Disconnect Battery: passo 3, immagine 1 di 1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove five screws holding battery in place and remove battery.
Conclusione
Altre 9 persone hanno completato questa guida.
Mike
Membro da: 06/23/16
1.834 Reputazione
5 Guide realizzate
iReconstruction Membro di iReconstruction
Business
1 Membro
11 Guide realizzate
3 Commenti
bonjour,
depuis que j’ai changé la batterie, elle ne charge plus… j’ai remis celle d’origine, idem…
Une idée?
merci d’avance.
Franck D'ALOIA - Replica
Bonjour,
J’ai le même phénomène que celui décrit plus haut par Franck D’ALOIA. La batterie de remplacement indique 100% de charge mais ne tient que 10min tout au plus.
Une idée ??
Merci à vous
Lamine Bouras - Replica
Minor correction to step #3 - the text says "remove 4 screws", but reality - and the photo - is that there are five screws.
Important: Note that the center one in the circular hole in the battery (under the trackpad) is a shorter length than the others.
davidhollway - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 267
Tutti i Tempi: 19,905
