Salta al contenuto principale
ThinkPad X1 Carbon Battery Replacement
Cosa ti serve
  1. ThinkPad X1 Carbon Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Unscrew the seven screws located on the back of the device
  2. ThinkPad X1 Carbon Battery Replacement: passo 2, immagine 1 di 1
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Battery Replacement: passo 3, immagine 1 di 1
    • Flip the device over and open it to lift the keyboard tray from the body of the device .
  4. ThinkPad X1 Carbon Battery Replacement: passo 4, immagine 1 di 1
    • Gently release the ribbon cable attached to the keyboard.
    • Gently Place keyboard tray to side.
  5. ThinkPad X1 Carbon Battery Replacement: passo 5, immagine 1 di 1
    • Unscrew the 4 screws holding the battery in place.
  6. ThinkPad X1 Carbon Battery Replacement: passo 6, immagine 1 di 1
    • Unlock and remove the ribbon cable running over the top of the battery.
  7. ThinkPad X1 Carbon Battery Replacement: passo 7, immagine 1 di 1
    • Gently pull the battery connection from the motherboard .
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 318
