Salta al contenuto principale
Thermaltake Theron Plus 5-pin USB Cord Replacement
Cosa ti serve
  1. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: passo 1, immagine 1 di 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: passo 1, immagine 2 di 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the plastic cover and pack of weights.
    • Remove the two 1.0 mm foam covers with tweezers.
    • Peel away the plastic screw cover with tweezers.
  2. Thermaltake Theron Plus 5-pin USB Cord Replacement: passo 2, immagine 1 di 2 Thermaltake Theron Plus 5-pin USB Cord Replacement: passo 2, immagine 2 di 2
    • Remove the four 1.0 mm screws with a Ph #1 screwdriver.
    • Gently remove the top of the mouse.
  3. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: passo 3, immagine 1 di 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: passo 3, immagine 2 di 3 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: passo 3, immagine 3 di 3
    Compra
    • Locate the 5-pin connector on the mouse's motherboard.
    • Use the tweezers to carefully pull the 5-pin connector off. Do this by grasping the connector and wiggling it back and forth until it is off.
    • Once removed, place new 5-pin connector on in the same way.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 640
