Salta al contenuto principale
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Theragun, usa il nostro manuale di assistenza.
  1. Theragun Teardown, Pry apart handle: passo 1, immagine 1 di 1
    • You can see that the cover has 2 pieces. There is a cover that snaps over the larger piece that conceals the fasteners. Pry apart, it will separate just like all the modern assemblies.
  2. Theragun Teardown: passo 2, immagine 1 di 1
    • Once you have removed the cover off the larger bezel, there are a few more fasteners underneath that aluminum plate. It is slightly glued and held in place by bending the tabs. Comes out fairly easily.
  3. Theragun Teardown: passo 3, immagine 1 di 1
    • This is the KEY to the whole thing. That cover is a vital mechanical component that is pressed in place. You will need to pry it off. I damaged mine slightly, with a bit of gentle heating I think you may be able to avoid damage.
  4. Theragun Teardown: passo 4, immagine 1 di 1
    • Here is the disassembled unit in all its glory.
  5. Theragun Teardown: passo 5, immagine 1 di 1
    • Mine had a worn bushing, on the left that caused the unit to be unbearably loud. You can see the top left of the first bushing is severely worn. I had a friend with a CNC machine make a few of these bushings. I have a few extras, contact me if you are in need of this part.
    • You can repair these
TS Sarkozi
Membro da: 12/31/25
133 Reputazione
1 Guida realizzata
2Commenti sulla guida
let me know step 3 detail.
It’s fitted so tightly that I can’t even find a gap. Where exactly should I pry it up from?
It would be helpful if there were a photo of the inside tabs for removal.
김도윤 - Replica Condividi
I actually damaged mine a bit. It is a very tight press fit. If I could do it over, I would cut a small gap 90 degrees apart on the circumference to pry it apart, but first use a heat gun to soften it up before prying.
TS Sarkozi - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 194
Tutti i Tempi: 569
