Salta al contenuto principale
The Claw Battery Replacement
Cosa ti serve
  1. The Claw Battery Replacement, Batteries: passo 1, immagine 1 di 1
    • Hold The Claw machine upright so that the controls are facing you.
  2. The Claw Battery Replacement: passo 2, immagine 1 di 1
    • Turn the device upside down keeping the controls facing in your direction.
  3. The Claw Battery Replacement: passo 3, immagine 1 di 1
    • Locate the battery compartment door on the bottom cover of The Claw.
    • Loosen the screw from the battery compartment door with your phillips head screwdriver.
  4. The Claw Battery Replacement: passo 4, immagine 1 di 1
    • Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
    • If the batteries are not placed in the right configuration the device will not operate. make sure to identify positive and negative sides of the battery and follow the configuration on the device.
Conclusione
Alain Pierre
Membro da: 03/22/16
1.188 Reputazione
9 Guide realizzate
Un commento
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
Jennifer Mateo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 36
Tutti i Tempi: 3,443
