Salta al contenuto principale
The Best Way To Replace iPhone XR Broken Back Glass
Cosa ti serve
Panoramica Video
  1. The Best Way To Replace iPhone XR Broken Back Glass, Laser The Back Glass: passo 1, immagine 1 di 2 The Best Way To Replace iPhone XR Broken Back Glass, Laser The Back Glass: passo 1, immagine 2 di 2
    • We put the whole phone into Blue Light Laser Separation Machine to laser the back glass so that we can easily remove the back glass, by then.
  2. The Best Way To Replace iPhone XR Broken Back Glass, Back Glass Removing: passo 2, immagine 1 di 2 The Best Way To Replace iPhone XR Broken Back Glass, Back Glass Removing: passo 2, immagine 2 di 2
    • The master will use a blade and a sharp knife to remove the back glass.
    • The back glass is very easy to be separated after doing laser. That’s why we choose to use blue light laser machine to separate the back glass. It can reduce the tear down difficulty of iPhone.
    • This is the final effect after taking apart the back glass.
  3. The Best Way To Replace iPhone XR Broken Back Glass, Cleaning: passo 3, immagine 1 di 3 The Best Way To Replace iPhone XR Broken Back Glass, Cleaning: passo 3, immagine 2 di 3 The Best Way To Replace iPhone XR Broken Back Glass, Cleaning: passo 3, immagine 3 di 3
    • Before cleaning black things. We should clean the glass around the edge with a small tool.
    • Once done, we continue to clean black things with clean cloth and alcohol.
    • Now, we’ve already clean up black things and finally there are many glue remaining. These glues are really useful because they are the key point to keep the same thickness as the original one.
  4. The Best Way To Replace iPhone XR Broken Back Glass, New Glue Adding: passo 4, immagine 1 di 2 The Best Way To Replace iPhone XR Broken Back Glass, New Glue Adding: passo 4, immagine 2 di 2
    • Here we add new glue around the phone body and blank place without glue.
    • You can see the final looking after adding glue in below picture.
  5. The Best Way To Replace iPhone XR Broken Back Glass, Install A New Back Glass: passo 5, immagine 1 di 2 The Best Way To Replace iPhone XR Broken Back Glass, Install A New Back Glass: passo 5, immagine 2 di 2
    • Stick a new back glass on the phone and use four clamping tool to hold the pressure.
    • The total replacement has been finished now. This is the final effect which the phone looks like as perfect as the original one.
Conclusione
If you are looking for the best way to take apart the back glass of cellphone and change it, you can come to see whether this way is suitable for you or not.
Altre 2 persone hanno completato questa guida.
FORWARD Lab
Membro da: 04/17/20
1.474 Reputazione
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,519
