Salta al contenuto principale
The Beatles Rock Band Hofner Bass Toggle Switch Replacement
Cosa ti serve
  1. The Beatles Rock Band Hofner Bass Toggle Switch Replacement, Back Plate: passo 1, immagine 1 di 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Toggle Switch Replacement: passo 2, immagine 1 di 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Toggle Switch Replacement: passo 3, immagine 1 di 2 The Beatles Rock Band Hofner Bass Toggle Switch Replacement: passo 3, immagine 2 di 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Toggle Switch Replacement, Toggle Switch: passo 4, immagine 1 di 2 The Beatles Rock Band Hofner Bass Toggle Switch Replacement, Toggle Switch: passo 4, immagine 2 di 2
    • With a J1 Phillips screwdriver, remove the six 5mm on the cover.
    • Remove the cover.
  5. The Beatles Rock Band Hofner Bass Toggle Switch Replacement: passo 5, immagine 1 di 1
    • Use a J1 Phillips screwdriver to remove the 10mm screw on the toggle switch.
  6. The Beatles Rock Band Hofner Bass Toggle Switch Replacement: passo 6, immagine 1 di 1
    • Remove the wire connecting the toggle switch to the blue circuit board.
    • Remove the toggle switch.
Conclusione
Jacob
Membro da: 01/25/17
601 Reputazione
6 Guide realizzate
Cal Poly, Team 8-4, Banghart Winter 2017 Membro di Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 442
