Salta al contenuto principale
The Beatles Rock Band Hofner Bass Fret Buttons Replacement
Cosa ti serve
  1. The Beatles Rock Band Hofner Bass Fret Buttons Replacement, Fret Buttons: passo 1, immagine 1 di 1
    • Flip the guitar onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 2, immagine 1 di 1
    • Flip the guitar to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 3, immagine 1 di 2 The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 3, immagine 2 di 2
    • Flip the guitar on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the guitar is now open.
  4. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 4, immagine 1 di 1
    • Using a J1 Phillips screwdriver, unscrew the 10mm screw at the base of the neck.
  5. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 5, immagine 1 di 1
    • Remove the head of the guitar, at the top of the neck. Do this by simply pulling on it, it should slide off out fairly easily.
  6. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 6, immagine 1 di 1
    • Use a J1 Phillips screwdriver to remove three silver 10mm screws at the top of the neck.
  7. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 7, immagine 1 di 1
    • Pop off the red button at the top by prying.
    • Use a J1 Phillips screwdriver to remove the 10mm screw underneath.
  8. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 8, immagine 1 di 2 The Beatles Rock Band Hofner Bass Fret Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the 10mm screw on the fret buttons with a J1 Phillips screwdriver.
    • Remove the fret buttons.
Conclusione
Jacob
Membro da: 01/25/17
601 Reputazione
6 Guide realizzate
Cal Poly, Team 8-4, Banghart Winter 2017 Membro di Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,391
