Salta al contenuto principale
The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide
Cosa ti serve
  1. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide, The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 1, immagine 1 di 1
    • Use the spudger to pry open the key fob shell by sliding it in between the front and back part of the key fob.
  2. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 2, immagine 1 di 1
    • To remove the buttons, lift the "rubber button pad'' from the key fob shell.
  3. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 3, immagine 1 di 1
    • Remove the old CR2032 battery by simply pulling it out and replace it with a new one.
  4. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 4, immagine 1 di 1
    • Insert rubber button pad over the battery. Place the front end of the key fob over the buttons and press down until you hear a "click".
  5. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 5, immagine 1 di 1
    • Press the vehicle lock button to ensure all doors of the vehicle are locked.
  6. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 6, immagine 1 di 1
    • Insert key into the ignition.
  7. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 7, immagine 1 di 1
    • Press and hold the unlock button on the driver side door. Do not release until prompted to do so in Step 10.
    • Swiftly turn the ignition ON and OFF.
  8. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 9, immagine 1 di 1
    • Release the unlock button on the driver side door. You should hear the vehicle automatically lock and then unlock.
  9. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: passo 10, immagine 1 di 1
    • Press the lock and unlock buttons on the key fob simultaneously until the vehicle automatically locks and unlocks (This can take approx. 30 secs.)
    • Turn ignition on to exit programming mode.
    • Turn vehicle off and remove key.
    • Test key fob by pressing the lock/unlock buttons to ensure functionality.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 53
Tutti i Tempi: 3,855
