Salta al contenuto principale
Introduzione
In this guide we will show how to access the motherboard and how to separate it from other internal components.
Need to place picture
Parti
Nessuna parte specificata.
  1. The first step to any repair operation is to remove the front cover. Grab the back of the calculator with one hand and the cover with the other. Pull the cover off from one of the sides for easy removal.
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Orientate the calculator with the top facing towards you. Slide the locking tab,found on the top part of the calculator, to the unlock position.
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. "Locking Tab" To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. The Batteries are now exposed and the calculator is face down with the back towards you. Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end. If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
  5. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  6. Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator. Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator. Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
    • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
  7. Unscrew the 19mm screw located near center of the back of the calculator.
    • Unscrew the 19mm screw located near center of the back of the calculator.
    • Remove the panel being held by the screw.
  8. Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
    • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
  9. Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
    • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
    • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
  10. Pull out the rectangular module when it is finally loose enough. Pull out the rectangular module when it is finally loose enough.
    • Pull out the rectangular module when it is finally loose enough.
  11. Now pull up on the back cover of the calculator while holding the rest of it flat on a surface. Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
    • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
    • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
  12. Pull the motherboard up while holding the rest of the calculator firmly in place The motherboard has now separated from the rest of the calculator The motherboard has now separated from the rest of the calculator
    • Pull the motherboard up while holding the rest of the calculator firmly in place
    • The motherboard has now separated from the rest of the calculator
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 15-51, Garner Spring 2010 Membro di Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,977
