Salta al contenuto principale
Texas Instruments TI-92 Backup Battery Replacement
Cosa ti serve
  1. Texas Instruments TI-92 Backup Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Texas Instruments TI-92 Backup Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Texas Instruments TI-92 Backup Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Texas Instruments TI-92 Backup Battery Replacement: passo 2, immagine 1 di 2 Texas Instruments TI-92 Backup Battery Replacement: passo 2, immagine 2 di 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Texas Instruments TI-92 Backup Battery Replacement: passo 3, immagine 1 di 2 Texas Instruments TI-92 Backup Battery Replacement: passo 3, immagine 2 di 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. Texas Instruments TI-92 Backup Battery Replacement, Backup Battery: passo 4, immagine 1 di 1
    • Before removing the backup battery make sure your AA batteries are installed so that there is no loss of information.
    • Using a #00 Philip Screwdriver remove the 19mm screw located near the center of the back of the calculator on the panel with words "Test Access"
  5. Texas Instruments TI-92 Backup Battery Replacement: passo 5, immagine 1 di 1
    • Remove the screw and lift the panel to access battery.
  6. Texas Instruments TI-92 Backup Battery Replacement: passo 6, immagine 1 di 2 Texas Instruments TI-92 Backup Battery Replacement: passo 6, immagine 2 di 2
    • The backup battery can now be seen underneath a small metal cover held by a screw.
    • Using the same screwdriver, unscrew the 4.6mm screw located under the panel and left of the backup battery.
  7. Texas Instruments TI-92 Backup Battery Replacement: passo 7, immagine 1 di 3 Texas Instruments TI-92 Backup Battery Replacement: passo 7, immagine 2 di 3 Texas Instruments TI-92 Backup Battery Replacement: passo 7, immagine 3 di 3
    • Remove the metal cover keeping the backup battery in place.
  8. Texas Instruments TI-92 Backup Battery Replacement: passo 8, immagine 1 di 2 Texas Instruments TI-92 Backup Battery Replacement: passo 8, immagine 2 di 2
    • Use an Ipod Opening Tool or a similar tool to pull up on the right side of the backup battery.
    • The battery should pop out of position.
  9. Texas Instruments TI-92 Backup Battery Replacement: passo 9, immagine 1 di 2 Texas Instruments TI-92 Backup Battery Replacement: passo 9, immagine 2 di 2
    • After the battery has been tilted out of its socket, simply remove it with your hands.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 15-51, Garner Spring 2010 Membro di Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 5,150
