Salta al contenuto principale
Texas Instruments TI-5130 Printer Unit Replacement
Cosa ti serve
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: passo 1, immagine 1 di 2 Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: passo 1, immagine 2 di 2
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Printer Unit  Replacement: passo 2, immagine 1 di 1
    • Flip the calculator back over and remove the top cover.
  3. Texas Instruments TI-5130 Printer Unit  Replacement: passo 3, immagine 1 di 1
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
  4. Texas Instruments TI-5130 Printer Unit  Replacement: passo 4, immagine 1 di 1
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
  5. Texas Instruments TI-5130 Printer Unit  Replacement: passo 5, immagine 1 di 2 Texas Instruments TI-5130 Printer Unit  Replacement: passo 5, immagine 2 di 2
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
wehre did you buy the replacement printer
Tino ullrich - Replica
what sources are there for TI-5130 printer unit?
Norman Todd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,278
