Salta al contenuto principale
Texas Instruments TI BA II PLUS Battery Replacement
Cosa ti serve
  1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: passo 1, immagine 1 di 2 Texas Instruments TI BA II PLUS  Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Switch off the calculator by pressing the button at the top right corner.
  2. Texas Instruments TI BA II PLUS  Battery Replacement: passo 2, immagine 1 di 1
    • Turn over the calculator so the backside of the calculator is facing upwards.
    • Remove the four 2mm Phillips #00 screws from the bottom cover.
  3. Texas Instruments TI BA II PLUS  Battery Replacement: passo 3, immagine 1 di 1
    • Open a small gap at the bottom of the calculator, using a spudger or your fingers.
    • Move your thumb from the bottom edge to the top.
    • Be gentle when separating the cases to avoid breaking the clips.
  4. Texas Instruments TI BA II PLUS  Battery Replacement: passo 4, immagine 1 di 3 Texas Instruments TI BA II PLUS  Battery Replacement: passo 4, immagine 2 di 3 Texas Instruments TI BA II PLUS  Battery Replacement: passo 4, immagine 3 di 3
    • Use a spudger to remove the battery from the cage at the bottom of the motherboard.
  5. Texas Instruments TI BA II PLUS  Battery Replacement: passo 5, immagine 1 di 1
    • Replace the battery with the new CR2032 Lithium Battery in the battery cage.
  6. Texas Instruments TI BA II PLUS  Battery Replacement: passo 6, immagine 1 di 2 Texas Instruments TI BA II PLUS  Battery Replacement: passo 6, immagine 2 di 2
    • Reattach the calculator cases, beginning from the top edge.
    • Use the Phillips #00 screwdriver to replace the 2.00 mm screws.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Un commento
It's amazing that this calculator can break. I am an accountant student in college and despite modern technologies and the rather powerful functionality of modern smartphones, I like to use just such a calculator for financial calculations.
AlGorFun - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 160
Ultimi 30 Giorni: 622
Tutti i Tempi: 21,647
