Salta al contenuto principale
Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement
Cosa ti serve
  1. Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: passo 1, immagine 1 di 3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: passo 1, immagine 2 di 3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: passo 1, immagine 3 di 3
    • Unlatch hooks all around the left casing (three on each side)
    • Carefully lift cover, fold it over and tape it to the head piece to get it out of the way. The NFC antenna is glued to the cover. Two wires connect it to the bundle.
    • Pry battery out w/ a spatula. You'll gain access to the speaker cables and can unsolder and replace the battery, if needed.
    • In case you need to get to the speaker, see https://de.ifixit.com/Anleitung/Teufel+A... for details.
Conclusione
andre
Membro da: 03/12/12
1.701 Reputazione
4 Guide realizzate
Un commento
Thank you very much for this guide!
Patch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 396
