Salta al contenuto principale
Introduzione
The boiler heat the water to the needed temperature for both the steam wand and portafilter. If your machine isn't heating up, one possible cause is a failed heating element inside the boiler. This guide will show you how to test for this.
Ricambi
Nessuna parte specificata.
  1. Remove the 6 Phillips #1 screws from the back panel. Remove the back panel.
    • Remove the 6 Phillips #1 screws from the back panel.
    • Remove the back panel.
  2. Make sure the machine is turned off and unplugged.
    • Make sure the machine is turned off and unplugged.
    • Set your voltmeter in continuity mode and place the leads on the two 90 degree prongs on the boiler's heating element.
    • It does not matter which lead touches which prong as you're just testing for a break, or "open" in the heating element circuit.'''
    • If the voltmeter shows 0, or "open", then there is an issue with the heating element's continuity and it needs to be replaced.
    • If given a reading, then your heating element is fine.
  3. In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
    • In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
    • Place a cup, to catch fluid, underneath the portafilter.
    • Run Barista, as if making coffee, for the amount of time directed by the de-calcifying product.
    • See the links section of the device page for further directions.
Conclusione
Altre 10 persone hanno completato questa guida.
Brian McMurray
Membro da: 31/01/2011
204 Reputazione
1 Guida realizzata
Cal Poly, Team 4-42, Regan Winter 2011 Membro di Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Membri
5 Guide realizzate
4 Commenti
I did this a few months ago and the boiler was full of rusty gunk. This guide sure did help me out.
oguitar200 - Replica
the same here - it was disgusting... was afraid to have damaged it while cleaning it. tested it yesterday already... just going through all the steps to validate function of the units.
Martin Zeitler -
hi ! we have Starbucks Barisa Milano. some how it didnt want switch on! my husband wanted to have a look but we cant open. do you gave any guidence?
Zorigoo Purev - Replica
I have a Barista and want to change the pressure washer of the coffee maker arm.
can any one help me?
sonnynima - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 56
Tutti i Tempi: 19,288
