Salta al contenuto principale
Tesla Model 3 Keyfob Battery Replacement
Cosa ti serve
Panoramica Video
  1. Tesla Model 3 Keyfob Battery Replacement, Prep: passo 1, immagine 1 di 1
    • Prepare a surface to work on (ensure it's won't damage the piano black exterior coating)
    • Gather your key fob and a small plastic spudger
  2. Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: passo 2, immagine 1 di 3 Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: passo 2, immagine 2 di 3 Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: passo 2, immagine 3 di 3
    • Using a small pry tool, gently press into the small indent near the front of the key fob while pressing up to pop off the battery cover.
    • Remove the coin-cell battery type CR2032 by prying upwards in the small recess
    • Insert a fresh CR2032 coin cell battery being sure to match the correct polarity of the original
    • If all you want to do is replace the battery, stop here. Otherwise check out my other guide for a full teardown!
Conclusione
IZ Labs
Membro da: 08/13/17
217 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 295
