Salta al contenuto principale
Tent Pole Shock Cord Replacement
Cosa ti serve
  1. Tent Pole Shock Cord Replacement, Tent Pole Shock Cord: passo 1, immagine 1 di 1
    • Remove the old shock cord from the tent poles.
  2. Tent Pole Shock Cord Replacement: passo 2, immagine 1 di 1
    • Measure and cut the string to the length of one tent pole piece.
    • Be sure to leave enough room on each end for knots.
  3. Tent Pole Shock Cord Replacement: passo 3, immagine 1 di 1
    • Tie the string to the end of the shock cord.
  4. Tent Pole Shock Cord Replacement: passo 4, immagine 1 di 2 Tent Pole Shock Cord Replacement: passo 4, immagine 2 di 2
    • Use your hands or pliers to flatten out a bobby pin.
    • Any long, thin, metal object will work to help feed the string and cord through the poles.
  5. Tent Pole Shock Cord Replacement: passo 5, immagine 1 di 1
    • Tie the string around the end of the bobby pin.
    • The string and bobby pin will be used to feed the shock cord through the pole.
  6. Tent Pole Shock Cord Replacement: passo 6, immagine 1 di 3 Tent Pole Shock Cord Replacement: passo 6, immagine 2 di 3 Tent Pole Shock Cord Replacement: passo 6, immagine 3 di 3
    • Drop the bobby pin and string through the tent pole pieces one by one.
    • Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
  7. Tent Pole Shock Cord Replacement: passo 7, immagine 1 di 2 Tent Pole Shock Cord Replacement: passo 7, immagine 2 di 2
    • Once the last piece has been threaded, untie or cut the string from the shock cord.
    • Tie a large knot against the right end of the last piece.
    • The knot must be large enough to prevent the shock cord from slipping through the pole.
  8. Tent Pole Shock Cord Replacement: passo 8, immagine 1 di 2 Tent Pole Shock Cord Replacement: passo 8, immagine 2 di 2
    • Connect the tent poles.
  9. Tent Pole Shock Cord Replacement: passo 9, immagine 1 di 1
    • Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
    • Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
  10. Tent Pole Shock Cord Replacement: passo 10, immagine 1 di 2 Tent Pole Shock Cord Replacement: passo 10, immagine 2 di 2
    • Tie a large knot around the tent pole end piece.
    • Fit the end piece into the left end of the first pole.
    • If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
  11. Tent Pole Shock Cord Replacement: passo 11, immagine 1 di 1
    • Disconnect the pole pieces.
    • Fold the pieces to test the shock cord tension.
    • If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
Conclusione
Altre 3 persone hanno completato questa guida.
Kelsea Weber
Membro da: 11/12/15
20.567 Reputazione
32 Guide realizzate
iFixit, Team S1-G1, Weber Summer 2018 Membro di iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
5 Membri
43 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 20,888
