Introduzione
This guide will show how to take the front glass off and move the screen out of the way on a Telikin Elite Silver 22in Touchscreen Computer
Cosa ti serve
Lay the computer down on a flat surface
Put your suction cups on the top corners of the screen
Pull upwards in an arching motion trying to pull the front glass towards yourself. It's held in place with magnets, some force may be required.
Disconnect the ribbon cables.
While wearing gloves remove the front glass and place it to the side
Remove the brackets on the top corners of the screen using a Phillips head screwdriver, put aside for reassembly.
Once the screen is unscrewed pull in a similar arching motion as you did the front glass.
When reassembling, ensure that the screen is flush with all four corners. Otherwise it will not seat back into the chassis properly.
