Salta al contenuto principale
Tektro Aires Disc Brakes Brake Pad Replacement
Cosa ti serve
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: passo 1, immagine 1 di 1
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: passo 2, immagine 1 di 2 Tektro Aires Disc Brakes Brake Pad Replacement: passo 2, immagine 2 di 2
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: passo 3, immagine 1 di 1
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: passo 4, immagine 1 di 1
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: passo 5, immagine 1 di 1
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: passo 6, immagine 1 di 1
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
Conclusione
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 65
Tutti i Tempi: 3,146
