Salta al contenuto principale
Tefal Thick N Thin Toaster 815032 Side Panels Replacement
Cosa ti serve
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: passo 1, immagine 1 di 3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: passo 1, immagine 2 di 3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: passo 1, immagine 3 di 3
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: passo 2, immagine 1 di 1
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: passo 3, immagine 1 di 2 Tefal Thick N Thin Toaster 815032 Side Panels Replacement: passo 3, immagine 2 di 2
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
83.152 Reputazione
204 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.524 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 194
