Salta al contenuto principale
Smontaggio Tefal Actifry
Cosa ti serve
  1. Smontaggio Tefal Actifry, Smontaggio Tefal Actifry: passo 1, immagine 1 di 3 Smontaggio Tefal Actifry, Smontaggio Tefal Actifry: passo 1, immagine 2 di 3 Smontaggio Tefal Actifry, Smontaggio Tefal Actifry: passo 1, immagine 3 di 3
    • Questo è il Tefal Actifry come lo vedi durante l'utilizzo. Dovrai girarlo a testa in giù per vedere le tre viti di sicurezza che dovrai svitare. Le ho evidenziate in rosso nella seconda immagine. L'ultima foto è un primo piano di una delle viti.
    BEFORE attempting ANY repairs not only do you switch off the electrical socket but remove the plug from the socket.
    I know some people will say “well that's obvious” but you would be totally amazed at how many “so called experts” don’t even bother.
    Tony
    Retired “Electro Mechanical Engineer”
    To F - Replica
    How do I get the security screws out? What sort of tool do I need as they have a pin in the screw so I cant put an allan key or screw driver in it
    Elaine Martin - Replica
    You need a Torx screwdriver with a size T-15H bit (a T-15 will also work). It looks like a star.
    leifhandjo -
    The paddle stopped turning on mine and after fitting a replacement motor the heater and fan did not work but the paddle did. After careful examination of the circuit board I noticed that the larger of the two fuses had blown. It looks like an antisurge fuse and it was very difficult to see if it was blown but my meter confirmed it was U/S. Unfortunately the fuse needs to be desoldered and a replacement soldered back onto the circuit board. All good afterwards. Tefal need to think about their philosophy and try to make stuff that lasts longer than 12 months and is also easier to repair.
    John - Replica
    The paddle on my actifry is still working but there is no hot air coming into the unit - is there any way of fixing this?
    Malinda Lambe - Replica
    Comment pouvez être sûr que c'est le moteur ?
    Dandipaola - Replica
  2. Smontaggio Tefal Actifry: passo 2, immagine 1 di 3 Smontaggio Tefal Actifry: passo 2, immagine 2 di 3 Smontaggio Tefal Actifry: passo 2, immagine 3 di 3
    • Quindi rimuovi le tre viti e la piccola copertura della ventola sulla parte superiore del dispositivo. Io ho fatto leva delicatamente su di questa con un coltello da burro.
    • Questo permette alla copertura inferiore del Tefal Actifry di venire rimossa, iniziando dalla parte della ventola, facendola quindi scorrere sopra i tasti di rilascio del coperchio per sfilarla dal dispositivo.
    Vielen Dank für die Beschreibung. Leider kann ich die Ventilatorabdeckung nicht lösen. Wo muss ich
    da mit einem Messer (?) ansetzen?
    b.girke - Replica
  3. Smontaggio Tefal Actifry: passo 3, immagine 1 di 3 Smontaggio Tefal Actifry: passo 3, immagine 2 di 3 Smontaggio Tefal Actifry: passo 3, immagine 3 di 3
    • Con la copertura inferiore rimossa, il motore è accessibile. Ci sono due viti di sicurezza delle stesse dimensioni di quelle sulla copertura che devi svitare. Ci sono due cavi che devono essere rimossi dal motore originale e messi su quello nuovo. Il nuovo motore può essere posizionato e fissato stringendo le viti.
  4. Smontaggio Tefal Actifry: passo 4, immagine 1 di 2 Smontaggio Tefal Actifry: passo 4, immagine 2 di 2
    • Una volta collegati i cavi saldamente nel nuovo motore ed è fissato con lee viti, puoi riposizionare la copertura inferiore del Tefal Actifry. Ricordati di infilarla seguendo al contrario la procedura di rimozione. Io ho avuto qualche problema a farla passare sopra i tasti, ma ci si riesce trovando la posizione corretta.
    Ich habe den Motor ausgebaut meiner Meinung sollte ich den im ausgebauten Zustand doch drehen können oder ?
    prinzringelmann - Replica
    Thanks for help, I tested the motor , it works!
    I need help to test the hot air fan, it looks like DC motor fan? what is the data sheet of it & how to test it either burnt or not?
    Best regards
    Akmal - Replica
  5. Smontaggio Tefal Actifry: passo 5, immagine 1 di 2 Smontaggio Tefal Actifry: passo 5, immagine 2 di 2
    • Ho smontato il motore originale per veedere cosa non andava. Ho trovato un magnete rotondo sul fondo, sotto i vari ingranaggi. Controllandolo più da vicino ho notato che era crepato e si è sfaldato appena lo ho toccato.
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 34 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Declan Green
Membro da: 05/02/14
1.056 Reputazione
1 Guida realizzata
35 Commenti
Thank you for the great guide. I'd like to mention a few things I discovered disassembling my actifry while following your instructions:
* the screws on my unit were regular torx - ie not security torx which have the pin in the middle that require bits with a corresponding hollow hole.
* the fan cover is made of very brittle plastic and is easy to break when trying to pry off.
* the fan cover is held by 3 tabs at the 9, 3, and 12'o clock positions. It is easiest to pry from the the tabs at 9 and 3'o clock positions.
ifabri - Replica
Thank you!! I am not at all DIY minded. I ordered a part for £12 on amazon, founder a screwdriver in my husband's toolbox, and fixed my actifry in under 5 minutes. Fab guide thank you!
Angharad - Replica
Hi I've just fitted a new motor but now not getting hot. Do you think I need to replace element too? Also my friend has an actifry with same problem but can't find a motor for the model AL806240. Any ideas where she can get one. The wires seem to sit differently than mine. Thank you
Jean Hennedy - Replica
This is what is happening to mine. I have replaced the motor and now the actifry is not heating… did you find the solution? Thanks
l.z.macintyre -
Thanks, saved time figuring out exactly how to do it - though you need a couple of more pictures in the guide. I had to deform the case a bit in order to clear over the fan otherwise it cannot slip over the fan - people be careful not to stress the fan assembly: you should slide the case without touching the fan.
In my case, the security screws *just* got unscrewed by a not-security screwdriver bit so I just replaced them with normal philips ones on reassembly.
MiKa - Replica
Muchas gracias. Pude arreglar mi Actifry gracias a su guía... Resulto perfecta,.
Resulta un poco difícil abrirla por los seguros plásticos, pero al final se pudo (uno se me rompió).
Best regard..
Arturo Miguel - Replica
The stirring motor in my Actifry stopped turning. When I removed the motor there was a lot of black sludge around the motor's output shaft and brown nicotine colored sludge covering the top of the motor and leaking right out the bottom of the motor.
Seeing as the motor was of no use as it was, I carefully bent back the tabs and lifted the top containing the gear train off the motor. The whole inside was also coated in the thick gooey sludge.
The motor shaft itself was free to turn when powered up. So I cleaned up the gears and shafts with lacquer thinner which quickly evaporates and lubricated them. After reassembling the motor and bending the tabs back down, I was back in business.
I noticed that the smaller Actifry model has much less of a build-up than the larger unit. The smaller model has a rubber seal at the bottom of the paddle, while the larger unit does not, allowing the sludge to accumulate quicker in the larger model which has a timer power off function, which I love.
John Cook - Replica
During the disassembly I accidentally let go of the wires attached to the motor. They're the same length and bend the same way. Does it make any difference which one goes where. I've senn one goes to J6 and one to J7 on the main board. Thx
Tho - Replica
Great advice, many thanks. I found my Actifry had the security torx screws, thought about it for a bit then used a fine centre punch and hammer to remove the little pins in the centre of the screws. It took a little care but meant that the torx screws came out easily. I also found that my motor was fine, it was just the drive shaft whose centre was driven clean, that did not engage to the motor. A very cheap fix but you do have to take the thing to pieces first.
David Merrett - Replica
I need help to replace the main motor of the Tefal actifry. Anyone who can help? with a step by step guide please.
Thanks
Patil Hunma - Replica
Hi,my fetal activity not turn on( no power on) please can you help me to find out the problem and how to fix it please?
Reg
Seelan
Tharmaseelan - Replica
Great guide. The hardest part was finding a TORX PLUS Tamper-Resistant bit, but once I’d dug one of those out of my assorted driver bits it was a doddle to change the drive motor.
johnctaylor59 - Replica
My actifry has no vents at the back for fan motor
Cooling
Later models
All have such grill at the back.
Do i need any precautions
Muhammad Atiq - Replica
Hi I have replaced the heating element in my actifry yet it still does not heat up. Any ideas?
Ahmed Ismail - Replica
Hi I've just got an actifry off ebay its saying Er 6 … do you know if this can fixed and if so how please? Thank you kind regards christine x
Christine Elaine - Replica
I did see two fuses on the “mother board behind the fan. One tested without a problem the other one ( on the left) has most probably blown.
The motor for the chip rotor makes a “false” sound, so that might be shot.
Where in New Zealand would I be able to: either get it repaired or at least get a new motor?
peter.vanderstam@gmail.com
Thanks so far.
Peter
Peter van der Stam - Replica
Hi, I am wondering where in New Zealand I can buy a motor and get one of the 2 fuses replaces.
They are soldered in which is a nuisance.
Would have been nice if they were easy to be replaced.
I am not sure, but I think that the left fuse is for the fan on the back.
Cheers and thanks so far.
Peter
Ask them, if they ship to NZ.
VauWeh -
Brilliant instructions fortunately I tried to unscrew the 3 screws before I bought the motor and realised I also needed to buy the special security screwdriver to remove them as well. very easy to follow instructions base fiddley to remove but no more than expected and gave a good opportunity to give all the parts a good clean. Simple as can be to remove and replace the motor and reassemble the u it. looks like new and working perfectly. Thank you
wendy.mabbott51 - Replica
Hi. My paddle was seized therefore I disassembled the motor as per the above instructions. Magnet is fine but everything was gummed up from grease. Cleaned everything, reassembled but now paddle is turning the wrong way?! In reverse! Help!
Marty - Replica
Did you ever resolve? My guess would be the wires gof crossed.
Sheldon Beck -
thanks! But as already mentioned on the comments, the fan cover is really easy to break while trying to disassembly it. I will glue it again, and well, it does not change the device funcionallity, but need to be mentioned
Cristian Röthig - Replica
Tefal Actifry Ah9500 error 6 manual guide does not help at all.The actifry stop working some times between 10-40 minutes of working.Any body knows what should be done to fix it?
p Takook - Replica
Error codes are useless even if you were a technician… it could be some resistor that when it overheats, shut down the device.
Daniele Carminati -
Here a page - well, it´s in german, use google translate - with solutions for common issues and errorcodes for Tefal Actifry. Error Code 6 is a little bit strange, voltage to high. Hmm, how can this happen?
VauWeh -
IMHO it is a pull down resistor in the power supply or on the board that is blowned shorted, so that the board gets a tension too high
Daniele Carminati -
I have repaired a family members device and the motor inside their actifry did not have the spades on the connection. I cut the terminal wires, put new spades on via crimping and connected to the new spaded motor and worked just fine.
Declan Green - Replica
Our paddle still turns. I've disassembled the unit and removed the heater element. That show 42ohms so I think it's ok. The fryer fan doesn't turn however and the fuse f2 is open circuit. I can get the motor assembly which includes the fuse. But would prefer a diagnosis prior to pulling out the parts gun!
Anyone delved deeper?
Gareth butler - Replica
I spoke to tefal, they do not help with troubleshooting, nor sell parts to consumers (from their twitter team).
They recommend only that you send it to the repair center and pay them…
Gareth butler -
I followed the guide but had trouble removing the front and back covers, managed in the end but they were brittle and will need replacing at next repair. Overall a quick and easy job and the replacement cost under £14 and arrived within 48hrs of ordering it
sim.cock - Replica
How do I replace the timer batteries
babsrog - Replica
I followed the instructions and managed to get the bottom casing off, I could see the motors but couldn’t tell which one is making the loud grinding noise. I suspect it would be the one with the fan, Without touching anything i switched it on for about 20 seconds to see if I could hear or see anything, It sounded perfect with no loud noise. Does anyone have any thoughts on this?
John Roberts - Replica
tefal actifry family serie 011-1 Showing error ( Er ) and beeps after about 2 minute Turn off and on. Set 1 min time and same error happens again every time within the 1 minute. Any suggestions
joerba - Replica
Might sound a bit hick but it worked. Underneath the paddle the two moving tabs that grip the spindle seemed a bit loose to me, so as a test I simply tightly folded a small piece of cardboard and jammed it in between the gap, between the 2 tabs and the spindle. Proved the point, it snapped on the chip pan as usual and actually turned. Now replace cardboard with foil, seems the tabs were to loose to grip the spindle, solved. You may need to redo now and again but saved a lot of hassle. Obviously clean paddle carefully, don't submerge in water or the foil may fall out.
Shelley S - Replica
Do you have a diagram/photo of the position of the small cogs in the paddle motor of a Tefal Actify Model serie 041?
Revell Cornell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 164
Ultimi 30 Giorni: 633
Tutti i Tempi: 115,264
