Salta al contenuto principale
Teenage Engineering OP-Z Volume Potentiometer Replacement
Cosa ti serve
  1. Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: passo 1, immagine 1 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: passo 1, immagine 2 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: passo 1, immagine 3 di 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 2, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 2, immagine 2 di 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 3, immagine 1 di 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: passo 4, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: passo 4, immagine 2 di 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 5, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 5, immagine 2 di 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: passo 6, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: passo 6, immagine 2 di 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 7, immagine 1 di 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Volume Potentiometer Replacement, Midframe: passo 8, immagine 1 di 1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 9, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 9, immagine 2 di 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 10, immagine 1 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 10, immagine 2 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 10, immagine 3 di 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 11, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: passo 12, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: passo 12, immagine 2 di 2
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  13. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 13, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 13, immagine 2 di 2
    • Use the spudger to disconnect the flex cable from the encoder board.
  14. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 14, immagine 1 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 14, immagine 2 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 14, immagine 3 di 3
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  15. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 15, immagine 1 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 15, immagine 2 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 15, immagine 3 di 3
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  16. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 16, immagine 1 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 16, immagine 2 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 16, immagine 3 di 3
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  17. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 17, immagine 1 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 17, immagine 2 di 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 17, immagine 3 di 3
    • Peel the highway flex cable off the midframe and remove it.
  18. Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: passo 18, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: passo 18, immagine 2 di 2
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
  19. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 19, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 19, immagine 2 di 2
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
  20. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 20, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 20, immagine 2 di 2
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
  21. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 21, immagine 1 di 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 21, immagine 2 di 2
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
  22. Teenage Engineering OP-Z Volume Potentiometer Replacement: passo 22, immagine 1 di 1
    • Remove the volume potentiometer.
Conclusione
Tobias Isakeit
Membro da: 03/31/14
117.588 Reputazione
188 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,120
