Salta al contenuto principale
Teenage Engineering OP-Z Rubber Feet Replacement
Cosa ti serve
  1. Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: passo 1, immagine 1 di 3 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: passo 1, immagine 2 di 3 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: passo 1, immagine 3 di 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Rubber Feet Replacement: passo 2, immagine 1 di 2 Teenage Engineering OP-Z Rubber Feet Replacement: passo 2, immagine 2 di 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Rubber Feet Replacement: passo 3, immagine 1 di 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Rubber Feet Replacement, Rubber Feet: passo 4, immagine 1 di 1
    • Remove the four Phillips #0 screws from the back of the rubber feet.
  5. Teenage Engineering OP-Z Rubber Feet Replacement: passo 5, immagine 1 di 2 Teenage Engineering OP-Z Rubber Feet Replacement: passo 5, immagine 2 di 2
    • Separate the front and rear part of the rubber feet from the back cover.
  6. Teenage Engineering OP-Z Rubber Feet Replacement: passo 6, immagine 1 di 1
    • When reassembling make sure to correctly align the front and rear part of the rubber feet. The notch and grove should interlock and fit into the cutout of the back cover.
Conclusione
Tobias Isakeit
Membro da: 03/31/14
109.704 Reputazione
188 Guide realizzate
iFixit Membro di iFixit
Community
141 Membri
17.717 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,263
