Salta al contenuto principale
Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement
Cosa ti serve
  1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: passo 1, immagine 1 di 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: passo 1, immagine 2 di 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: passo 1, immagine 3 di 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 2, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 2, immagine 2 di 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 3, immagine 1 di 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Battery: passo 4, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Battery: passo 4, immagine 2 di 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 5, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 5, immagine 2 di 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Expansion Module: passo 6, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Expansion Module: passo 6, immagine 2 di 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 7, immagine 1 di 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Midframe: passo 8, immagine 1 di 1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 9, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 9, immagine 2 di 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 10, immagine 1 di 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 10, immagine 2 di 3 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 10, immagine 3 di 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 11, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Pitch Bend Button: passo 12, immagine 1 di 2 Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Pitch Bend Button: passo 12, immagine 2 di 2
    • Use a spudger or your finger to push the pitch bend button inwards.
  13. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: passo 13, immagine 1 di 1
    • Carefully lift and remove the pitch bend button.
    • The button has two small holes which engage with two pins in the midframe.
    • Make sure the two holes and pins align when reinstalling the new button.
Conclusione
Tobias Isakeit
Membro da: 03/31/14
117.598 Reputazione
188 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.535 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,678
