Introduzione
Usa questa guida per sostituire il cavo flex highway, che comprende la porta USB-C e il jack cuffie / line out dell'OP-Z.
Cosa ti serve
Sblocca i quattro piedini di gomma ruotandoli di 90° in senso antiorario usando il pollice o la punta di un dito.
Usa uno spudger o un'unghia per sollevare la batteria dal lato destro, in corrispondenza dell'intaglio nella scocca.
Usa uno spudger o un dito per premere la piccola aletta sul fondo del modulo.
Solleva il modulo fuori dal suo alloggiamento iniziando dalla parte inferiore.
Usa uno spudger per disconnettere il cavo flex highway dalla scheda DSP.
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
albertob ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
3 Commenti
It worked! Sort of. I bought a highway flex cable replacement and a new battery hoping it would solve an issue. The good news is I was able to replace it, and it’s function as before I replaced the flex cable. The only challenge really was that the audio cable plug in the new flex cable assemble was slightly bigger than the one I removed. I really had to force it down. During reassemble it was important to start left to right too - and it was easier to plug that last cable before installing the audio and USB C sockets. The issue I was trying to solve: My OP-Z will only power on when plugged in. I bought the OP Z used, and it worked fine for a while. But for reasons I can’t explain it stopped working with battery power alone. I tried all the solutions I found online including resetting the battery, firmware, etc. I’m just sharing this in case someone else has the same issue. Other than that, the new flex cable works just like the one it replaced, and I have an extra one now! Thank you!!!
