Introduzione
Use this guide to replace a worn-out or dead battery in your OP-Z.
Cosa ti serve
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
Use your fingernail or a spudger to lift the battery on the right side where the notch is.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
Altre 4 persone hanno completato questa guida.
