Salta al contenuto principale
Teenage Engineering OP-Z Back Cover Replacement
  1. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Back Cover Replacement: passo 2, immagine 1 di 2 Teenage Engineering OP-Z Back Cover Replacement: passo 2, immagine 2 di 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove the bottom plate including the rubber feet.
Conclusione
Tobias Isakeit
Membro da: 03/31/14
117.588 Reputazione
188 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,501
