Salta al contenuto principale
Teddy Ruxpin Arm Button Replacement
Cosa ti serve
  1. Teddy Ruxpin Arm Button Replacement, Battery: passo 1, immagine 1 di 2 Teddy Ruxpin Arm Button Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Arm Button Replacement: passo 2, immagine 1 di 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Arm Button Replacement: passo 3, immagine 1 di 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Arm Button Replacement, Arms: passo 4, immagine 1 di 3 Teddy Ruxpin Arm Button Replacement, Arms: passo 4, immagine 2 di 3 Teddy Ruxpin Arm Button Replacement, Arms: passo 4, immagine 3 di 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Arm Button Replacement: passo 5, immagine 1 di 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Arm Button Replacement: passo 6, immagine 1 di 3 Teddy Ruxpin Arm Button Replacement: passo 6, immagine 2 di 3 Teddy Ruxpin Arm Button Replacement: passo 6, immagine 3 di 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Arm Button Replacement: passo 7, immagine 1 di 2 Teddy Ruxpin Arm Button Replacement: passo 7, immagine 2 di 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Arm Button Replacement: passo 8, immagine 1 di 2 Teddy Ruxpin Arm Button Replacement: passo 8, immagine 2 di 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Arm Button Replacement: passo 9, immagine 1 di 1
    • Unplug the arms from the main body.
Conclusione
Altre 4 persone hanno completato questa guida.
Lauren
Membro da: 01/23/20
226 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G5, White Winter 2020 Membro di Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Membri
7 Guide realizzate
4 Commenti
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - Replica
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - Replica
So has anyone figured out how to replace the button?
knrobinson83 - Replica
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
Eliza Zollicoffer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 983
