Salta al contenuto principale
Technique - Test the Battery
Cosa ti serve
  1. Technique - Test the Battery, Technique - Test the Battery: passo 1, immagine 1 di 3 Technique - Test the Battery, Technique - Test the Battery: passo 1, immagine 2 di 3 Technique - Test the Battery, Technique - Test the Battery: passo 1, immagine 3 di 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: passo 2, immagine 1 di 2 Technique - Test the Battery: passo 2, immagine 2 di 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: passo 3, immagine 1 di 2 Technique - Test the Battery: passo 3, immagine 2 di 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Conclusione
Melinda Phan
Membro da: 04/17/11
438 Reputazione
9 Guide realizzate
Cal Poly, Team 9-64, Walters Spring 2011 Membro di Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Membri
18 Guide realizzate
2Commenti sulla guida
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Replica
yes,not tablet with battery removal difficult
paulbeames7 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 10,728
