Salta al contenuto principale
Teac DC-D2831 Drive Belt replacement
Cosa ti serve
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: passo 1, immagine 1 di 2 Teac DC-D2831 Drive Belt replacement, Drive Belt: passo 1, immagine 2 di 2
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: passo 2, immagine 1 di 1
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: passo 3, immagine 1 di 3 Teac DC-D2831 Drive Belt replacement: passo 3, immagine 2 di 3 Teac DC-D2831 Drive Belt replacement: passo 3, immagine 3 di 3
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: passo 4, immagine 1 di 1
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
Conclusione
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 2-61, Propen Fall 2012 Membro di Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,592
