Introduzione
The turntable is operated by a motor that spins a belt and the table. The belt may stretch or become misaligned over time, and may need replacement or adjustment. Note that it is first important to complete the Disassembly Guide.
  1. Separate the turntable from the top of the record player by lifting straight up. Separate the turntable from the top of the record player by lifting straight up.
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle). It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel. It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  5. Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
Conclusione
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
Charles Lockner
Membro da: 17/09/2012
103 Reputazione
2 Guide realizzate
Cal Poly, Team 2-61, Propen Fall 2012 Membro di Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,312
