Salta al contenuto principale
Tatung TAC-6G Power Cord Replacement
Cosa ti serve
  1. Tatung TAC-6G Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Lift the lid and bowl from the top of the device.
    • Be sure device is not plugged in before beginning replacement of power cord.
  2. Tatung TAC-6G Power Cord Replacement: passo 2, immagine 1 di 1
    • Turn device upside-down so that the three legs point upwards.
  3. Tatung TAC-6G Power Cord Replacement: passo 3, immagine 1 di 1
    • Remove the one 7mm Phillips Head #3 spanner screw from the side of the brass panel.
  4. Tatung TAC-6G Power Cord Replacement: passo 4, immagine 1 di 1
    • Lift the brass plate from the device and set it aside.
  5. Tatung TAC-6G Power Cord Replacement: passo 5, immagine 1 di 1
    • Remove the 7mm Phillips #3 brass screw that connects the white power cord wire and blue wire closest to the power cord.
  6. Tatung TAC-6G Power Cord Replacement: passo 6, immagine 1 di 1
    • Remove the 10mm Phillips #3 brass screw above the heating element that connects the white power cord wire and the maroon wire.
  7. Tatung TAC-6G Power Cord Replacement: passo 7, immagine 1 di 1
    • Using your hands, from the inside of the device, push the black plastic wire holder to release cords.
  8. Tatung TAC-6G Power Cord Replacement: passo 8, immagine 1 di 1
    • Pull the power cord through the hole, isolating the power cord from the device.
  9. Tatung TAC-6G Power Cord Replacement: passo 9, immagine 1 di 1
    • Thread the new power cord wires into the hole.
    • To ensure the power cord is compatible with the device, make sure that the replacement cord you are using has a proper insulating coating and uses a NEMA 1 plug. NEMA 1 plugs are the common type of plug that have two parallel "|" shaped metal beams.
Conclusione
2 Commenti
Thanks! Ours wore out at the crimped part where the cable exits the rice cooker. After opening it up, we cut the cable ~6" from the loose end (not the plug end!), separated the two wire bundles, stripped part of the black plastic off (~1/5") slid the fiberglass sheaths over to the new bundles and attached w/o the circle metal ends by screwing it into the original place.
carole - Replica
Where do you get this particular replacement power cord?
Riceman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,601
