Salta al contenuto principale
Tatung TAC-6G Heating Element Replacement
Cosa ti serve
  1. Tatung TAC-6G Heating Element Replacement, Heating Element: passo 1, immagine 1 di 1
    • Lift the lid and bowl from top of the device
    • Be sure device is not plugged in before beginning replacement of heating element
  2. Tatung TAC-6G Heating Element Replacement: passo 2, immagine 1 di 1
    • Turn the bowl upside down so that the three legs point upwards
  3. Tatung TAC-6G Heating Element Replacement: passo 3, immagine 1 di 2 Tatung TAC-6G Heating Element Replacement: passo 3, immagine 2 di 2
    • Remove the one 7 mm Phillips screw from the side of the brass panel.
  4. Tatung TAC-6G Heating Element Replacement: passo 4, immagine 1 di 2 Tatung TAC-6G Heating Element Replacement: passo 4, immagine 2 di 2
    • Remove the 6mm Phillips screw that holds the stainless plate.
  5. Tatung TAC-6G Heating Element Replacement: passo 5, immagine 1 di 3 Tatung TAC-6G Heating Element Replacement: passo 5, immagine 2 di 3 Tatung TAC-6G Heating Element Replacement: passo 5, immagine 3 di 3
    • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
  6. Tatung TAC-6G Heating Element Replacement: passo 6, immagine 1 di 1
    • Using your hands, remove the heating plate that is on top of heating element.
  7. Tatung TAC-6G Heating Element Replacement: passo 7, immagine 1 di 1
    • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
  8. Tatung TAC-6G Heating Element Replacement: passo 8, immagine 1 di 1
    • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
  9. Tatung TAC-6G Heating Element Replacement: passo 9, immagine 1 di 1
    • Using, your hands, take out the heating element and replace it with a new one.
Conclusione
6 Commenti
where can I buy this heating element? Thanks.
dchang168 - Replica
Tze Moh Yeo - Replica
where to buy parts is the problem!!
William Co - Replica
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 4,077
