Introduzione
Follow this guide to remove the traveling valve. If you wish to replace the entire valve, you will not need to follow the disassembly steps towards the end. Follow those steps if you wish to inspect, repair, or replace an individual component of the traveling valve.
Cosa ti serve
While holding onto the pump rod, use a Tara tool to loosen the jam nut from the hook.
Quasi finito!
Conclusione
